Audio/Visual Electronics FAQ
Old Jan 6, 2007 | 06:09 PM
amg6975's Avatar
Default Audio/Visual Electronics FAQ
Q: I have a 96-98 and I just got an aftermarket head unit, why doesn't my keyless work anymore?
A: Because, your factory keyless reciever is in the factory head unit. You'll need to get a special wire harness and stuff your factory head unit back up under the dash if you want your keyless to work again.
Q: I have a 96-00 LX, can I get factory keyless? / How do I program my keyless remotes?
A: Yes! All 96-00 (Maybe 01- up too)Civics with power locks have the reciever for keyless, all you need are the remotes. Once you get the remotes look here for programming instrucations. http://www.honda-acura.net/forums/showthread.php?t=202634
Q: What's an Ohm?
A: Ohm is a unit of resistance or, in our case impedence since sound isn't DC. The symbol for impendence is Z. Anyways, here's how to calculate your total impedence.
Series:
Z(total) = Z1 + Z2 + Z3 + ...
Parallel:
1/Z(total) = 1/Z1 + 1/Z2 + 1/Z3 + ...
Q:I still can't find what I'm looking for, what do I do?
A: Check out www.the12volt.comfor almost everything you'll need.
Q: I'm a newb, what system should I get?
A: do some homework, the search button is in the top right.
tarheels131
Dec 31, 2023 09:12 PM
DanoATX
Oct 27, 2009 06:52 PM
digimon916
Apr 28, 2007 12:22 PM
FRENUM822
Dec 19, 2006 07:01 AM
sandrider123
Feb 14, 2006 09:06 AM
