General Tech Help
Old Feb 21, 2005 | 02:39 PM
XCM828's Avatar
Default General Tech Help
Research Information
www.howstuffworks.com
All of your engine oil questions answered: http://www.chris-longhurst.com/carbi...oil_bible.html
Manuals & Parts Catalogs
92-95 Civic Helms Manual: http://www.televar.com/soxen/92-95-helms.pdf
5th gen Civic service manual: http://www.honda.co.uk/owner/civicManual/index.html
Various UK manuals: http://www.honda.co.uk/owner/serviceManualsPdf.jsp
Parts Catalogs & Manuals: http://icelord.net/honda/repair/
Engine & Tuning & Cooling
Building a Honda engine: http://www.theoldone.com/articles/badtothebone/
Piston data sheet: http://www.theoldone.com/articles/en...ata_sheet.html
Connecting rod instructions: http://www.theoldone.com/articles/en...ata_sheet.html
Pistons: http://www.theoldone.com/articles/en...ppistons1.html
Building a D series: http://www.theoldone.com/articles/d%...ilding%5Ftips/
Cylinder head porting and analysis: H22A B16A D16A
Honda/Acura Engine Codes: http://www.honda-acura.net/forums/sh...ht=engine+code
How To Break In Your Engine For More Power & Less Wear: http://www.mototuneusa.com/break_in_secrets.htm
Adapting Type-R Manifold to B18B/B20B: http://www.theoldone.com/articles/conversion/
Skunk2 B18C1 intake manifold DIY (it's not just a bolt-on mod, the TB bracket will hit your hood if you don't follow these instructions): http://www.ff-squad.com/tech/howto/sk2manifold/
Skunk2 B18C1 intake manifold & Hondata intake gasket DIY: http://repo.jackmoves.com/album215
Oil pressure gauge install: http://www.theoldone.com/articles/oilpressure/
How to Change DelSol Spark Plugs: http://www.impactsites2000.com/autozone/delsolmod_1.htm
How to Install an Aftermarket Air Intake on a DelSol: http://www.impactsites2000.com/autozone/delsolmod_2.htm
Check Engine Light (CEL), what do I do?: http://www.c-speedracing.com/faq/03.php
Check your Check Engine Light (CEL): http://www.c-speedracing.com/faq/06.php
Define your Check Engine Light (CEL): http://www.c-speedracing.com/faq/05.php
Resetting DelSol's ECU: http://www.austrosol.com/tips/reset_ecu_eng.htm
KILLER ECU Info: http://ecu.ff-squad.com/info.htm
More Tech Info than you can shake a stick at: http://technet.ff-squad.com/
OBD1 P30 ECU Pinout: http://tech2.hybridgarage.com/ecu.php?ecutype=p30_obd1
OBD1 P72 ECU Pinout: http://tech2.hybridgarage.com/ecu.php?ecutype=p72_obd1
D and B series engine specifications: http://hybrid2.honda-perf.org/tech/engine.html & http://www.bseries.net/html/specs/benginespecs.php (Bseries only)
DIY Boost Controllers: http://www.c-speedracing.com/howto/mbc/mbc.php
Another DIY Boost Controller: http://www.geocities.com/chmwatson/FAQs/mbc.html
VAFC Installation: http://www.turbod16.com/viewtopic.php?t=1633
Another VAFC Installation: http://www.bseries.net/html/garage/vafc.php
96-2k Integra radiator swap (doesnt retain AC): http://repo.jackmoves.com/albun46
96-2k Greddy oil filter relocation kit install: http://repo.jackmoves.com/album128
96-2k Greddy oil catch can install (NA/FI): http://repo.jackmoves.com/album130
Turbo'd B18C1 Greddy 9mm catch can install: http://www.honda-acura.net/forums/sh...d.php?t=106716
Bseries STR Cam Seal Install: http://repo.jackmoves.com/album159
Bseries Skunk2 Cam Gear Install: http://repo.jackmoves.com/album158
Fuel Components
Fuel Pump Replacement: http://www.honda-acura.net/forums/sh....php?p=2337636
Properly installing fuel pumps: http://www.theoldone.com/articles/fuelpump
Drivetrain
Easy axle replacement: http://www.honda-acura.net/forums/sh...d.php?t=173647
Clutch/Flywheel upgrade DIY: http://www.honda-acura.net/forums/sh....php?p=1715569
Bseries tranny specs: http://www.bseries.net/html/specs/btrannyspecs.php
Hybrid
92-95 Civic B18C1 swap: http://www.c-speedracing.com/howto/b18cswap/swap.php
96-2k B18C swap: http://repo.jackmoves.com/albun45
Site dedicated to Hybrids w/ tech articles and DIYs: http://www.hybridgarage.com/
Tech articles and DIYs from above: http://tech.hybridgarage.com/tech/index.html
Kseries into 92-95 Civic, 94-97 Sol, 94-01 Teg: http://www.k20a.org/EGK1.pdf
Kseries into EK: http://www.k20a.org/EKK1.pdf
Brakes & Suspension
Civic/Teg - Changing front & rear disc brake pads and rotors: http://www.g2ic.com/tegtips/brakesus/5.html
5th gen (1992 - 1995) Civic Rear Disc Brake Conversion: http://www.hybridgarage.com/tech/brakeswap.html
Skunk2 camber kit DIY install: http://www.honda-acura.net/forums/sh...d.php?t=127432
Ingalls camber kit install ('92-'95): http://www.honda-acura.net/forums/sh...94#post1585894
Rear Camber Adjustment (Cheaper than a Kit): http://home.earthlink.net/~civicex95/rearcamber.html
96-2k rear integra disc brake swap: http://repo.jackmoves.com/album55
JDM ITR master cylinder/brake booster: http://www.honda-acura.net/forums/sh...d.php?t=134103
Wheel offset explained: http://www.honda-acura.net/forums/sh...50&postcount=2
Exterior
'96-'98 Civic all OEM power window converstion: http://repo.jackmoves.com/album206
Honda Civic 96-00: DIY CTR Headlights Guide(with Pictures): http://www.honda-acura.net/forums/sh...00#post1587100
How To Install JDM Side Markers on EG: http://students.washington.edu/krist.../side/side.htm
99-00 Si Lip Install on EG: http://www.jdmvtec.com/silipinstall.html
EG Type R Lip Install: http://www.autodynamic.com/transfer/...ykit-typer.htm
EG Power Mirror Installation Guide: http://www.courtlukens.com/folding_mirror.htm
Sylvania Automotive Light Replacement Guide: http://www.sylvania.com/auto/carapp/
92-95 to 96-2k mirror conversion: http://repo.jackmoves.com/album104
99-2k Grille removal (hardly a how to): http://repo.jackmoves.com/album146
Interior
Integra GSR/ITR Cluster in EG/EK: http://patriot.net/~merritt/gauge.html
Integra GSR Cluster in EG: http://www.geocities.com/cinq112/gsrclusterswap.html
6th Gen gauge cluster swap - no tach to tach: http://repo.jackmoves.com/album161
96-98 Civic Dash swap to 99-00: http://repo.jackmoves.com/album228
5th Gen climate control removal and change-over to the JDM pannel: http://www.clubcivicquebec.com/site/...metic/005.html
Gauge Cluster Swap + more: http://honda-acura.net/forums/showth...31#post2146031
Security
Fuel Pump Cutoff Switch: http://www.teamdelsolwa.com/howto/fuelcutoff.htm
Misc & Large Listings
Everything you need to know about turbos: http://www.beesandgoats.com/boostfaq/g2icturbo.html
Many excellent engine/suspension/fuel/etc. DIYs: http://www.c-speedracing.com/howto.php
Many, many important resources: http://www.hondaswap.com/forums/index.php?showforum=33
B-series piston measurements: http://www.theoldone.com/articles/pistons/
92-95 power window/mirror/lock conversion: http://repo.jackmoves.com/albun42
96-2k Power steeri
Old Feb 22, 2005 | 07:08 PM
XCM828's Avatar
Default RE: General Tech Help.
If you find some other good sites, send me the link and I'll add it.
Old Sep 6, 2005 | 01:03 AM
rx9790's Avatar
Several of the links are dead now. Just an FYI.
Old Dec 18, 2006 | 12:47 AM
hawiian boy's Avatar
Where can I download 99 Honda civic service MAnual
Thanks.
HAwaiian boy
Old Jan 13, 2007 | 06:11 PM
loFreqncy's Avatar
all of the repo.jackmoves.com links are broken.
Old Jan 13, 2007 | 06:17 PM
drbyers's Avatar
doesn't matter because XCM hasn't posted in almost six months.
he was talking about selling his civic.
Old Mar 17, 2007 | 10:42 PM
cookie's Avatar
i have 99 integra obd2 engine try to put 93 civichatchback obd1.what do i need tochange to convert the obd2 to becomeobd1.
Old Mar 17, 2007 | 10:45 PM
cookie's Avatar
what axle should i use to my 93 civichatchback with 99 integra engine.[&o]
Old Jun 4, 2007 | 08:33 AM
wendy's Avatar
I have a 2001 civic and the check engine light came on and the manifold got so hot,it cracked.I replaced the catalytic converter and the manifold and it did it again.It will lose power and the check engine light comes on.It never registers hot and it runs fine after I let the engine cool off for about 5 minutes.This last time the key light came on as welland the check engine light went off by itself but the manifold was glowing it got so hot instantly.Does anybody know whats causing this problem?
Old Jun 19, 2007 | 04:25 AM
imsquisht's Avatar
Just bought this 94 hatch, have a accelaration problem,Step on the throttle hard and it falls on its face and sucks a lot of air.Slow accelaration it runs fine but you can not give it more than 1/4 throttle till you get theR's up.has a D15B Vtec 2601072 motor, 37820-P08-020 460 306860 Ecu,5 Speed anybody got any sugestions?
Steve
