Solved Problems (Check Here First)
Old Sep 19, 2005 | 09:40 PM
XCM828's Avatar
Default Solved Problems (Check Here First)
This is a list of various problems people have had solved by HCF users. Before you post, skim these lists because somebody might have already fixed your problem. If you have had a problem solved in any of the forums, please PM me and I will add them to the list. Enjoy!
General
1. Cranks but won't start: https://www.hondacivicforum.com/m_97980/tm.htm
2. Intermittent starting and stalling problems: https://www.hondacivicforum.com/m_82668/tm.htm
Cooling, Heating, and A/C
1. Water temp. needle moving up and down: https://www.hondacivicforum.com/m_91868/tm.htm
2. A/C smell: https://www.hondacivicforum.com/m_92756/tm.htm
3. Overheating problems: https://www.hondacivicforum.com/m_82002/tm.htm
4. A/C vent rattle: https://www.hondacivicforum.com/m_79630/tm.htm
Fuel and Exhaust
1. Car bogs during acceleration: https://www.hondacivicforum.com/m_96852/tm.htm
Engine Electrical
1. Replacing distributor: https://www.hondacivicforum.com/m_98965/tm.htm
2. Car starting problems: https://www.hondacivicforum.com/m_81093/tm.htm
3. No spark: https://www.hondacivicforum.com/m_82923/tm.htm
4. Car bogs in lower RPM band: https://www.hondacivicforum.com/m_133369/tm.htm
Transmission
Clutch and Driveline
1. Grinding noise in axle bearings: https://www.hondacivicforum.com/m_94069/tm.htm
Brakes
1. E-brake light flickering: https://www.hondacivicforum.com/m_97413/tm.htm
2. Brake noise (with sounds clips): https://www.hondacivicforum.com/m_89552/tm.htm
3. Rotor screws: https://www.hondacivicforum.com/m_15.../tm.htm#155685
Suspension and Steering
Body
1. Removing bumper cover: https://www.hondacivicforum.com/m_98838/tm.htm
2. Trunk lever not opening trunk: https://www.hondacivicforum.com/m_96511/tm.htm
3. Water under driver's left foot: https://www.hondacivicforum.com/m_66590/tm.htm
4. Water under passenger seat: https://www.hondacivicforum.com/m_58633/tm.htm
Chassis Electrical
1. Resetting SRS light: https://www.hondacivicforum.com/m_99522/tm.htm
2. Aiming headlights: https://www.hondacivicforum.com/m_94836/tm.htm
3. Window rolls up slowly: https://www.hondacivicforum.com/m_79971/tm.htm
4. Stereo not working after power disconnected: https://www.hondacivicforum.com/m_89985/tm.htm
5. Window comes off of track: https://www.hondacivicforum.com/m_124507/tm.htm
Random
1. Door froze shut: https://www.hondacivicforum.com/m_134084/tm.htm
Old Sep 19, 2005 | 09:50 PM
Remmy's Avatar
Default RE: Solved problems. Check here first.
If it looks good and understandable it will be.
Old Sep 19, 2005 | 10:24 PM
mxs's Avatar
mxs
oh god... I have a bunch for you
Old Sep 19, 2005 | 10:34 PM
XCM828's Avatar
Please PM me the links! Skimming all of these posts is going to be a bitch so please send me links to any problems you had solved in any of the forums.
I'm tired, so I'll work on it more tomorrow. PM me links please!
Old Sep 20, 2005 | 09:56 PM
XCM828's Avatar
Ok so now you guys get the basic idea of what I'm aiming for. PM me all your links to problems you've had solved (doesn't have to be in just the General Tech forums) so we can get this list going.
Old Sep 20, 2005 | 10:07 PM
ngoti 8tor's Avatar
Great idea, XCM.
Old Oct 2, 2005 | 02:51 PM
Civic89Hatch's Avatar
My civic isnt gett any spark, replaced the distributor and the cap im just not gettin any power to the distributor all the fuses check out ok
Old Oct 2, 2005 | 03:05 PM
ohbiskits's Avatar
ill bet your timing belt popped
Old Feb 15, 2006 | 07:30 AM
slick0899's Avatar
Hey Guys,
Did complete tune-up on 2000 Civic. Replaced plugs, wires, cap & rotor.
Drove down the street and engine light came on. Ran a little rough too.
Checked out wires with Ohm meter, everything checked out ok. What might have I done to cause this problem. Help, this is my only car.
Ken
Old Jan 15, 2007 | 08:04 AM
therivler1's Avatar
Hey OP,
Solved my squeaking problem:
https://www.hondacivicforum.com/m_336660/tm.htm
