General Tech Help
Old Apr 14, 2009 | 10:09 AM
  #41
jasonm5291's Avatar
Default b18c turboed exhaust
i am putting a b18c turboed motor in my 95 civic and my exhaust does not match up i have a 2.5 inch exhaust on the motor but a 1.5 inch exhaust system on the car and i want to go with a dc sports exhaust system how do i go about doing this PLEASE HELP
Old Apr 16, 2009 | 12:57 PM
  #42
I don't understand what you are asking...
didn't you just answer your own question? (get aftermarket exhaust)
Old May 9, 2009 | 05:36 PM
  #43
kyle045's Avatar
Default Help
Hello there my name is kyle, i just bought a 1999 honda civic dx, it is super n nice and i love it. problem is i have 2 problems. The dash doesnt have tacks on it, is there any way that i can replace it with a dash that has tacks on it?? or a cheap gauge. i do not know how to wire it up so who would help me. And my other problem is, is that the horn doesnt work. where is it located? and maybe a wire is faulty or something, do i just replace that or should i go to an autowrecker and grab a horn from there?? thanks for your help everybody.
Old May 9, 2009 | 06:30 PM
  #44
any 1996-2000 Civic Gauge cluster will plug and play in your dash. No additional wiring required, just a nice clean direct swap. Just get one that has a tach. (EX, LX (i think), and Si are your options).
Old May 10, 2009 | 11:18 AM
  #45
kyle045's Avatar
Default Help me!
hi its kyle again. i am about to buy a set of xenon headlights off ebay and the business put out a warning for these headlights by saying this REMARK: If your car has SEALED BEAM HEADLIGHTS, these pair of light bulbs would not fit! are 1999 honda civic dx headlights sealed?? i hope not! please anybody who knows tell me. thanks
Old Aug 23, 2009 | 08:58 AM
  #46
oldskoolstang's Avatar
A sealed beam headlight is like what my 1970 Mustang has. Your 99 Civic does not have a sealed bulb. You can change just the bulbs, not the whole sealed beam headlight assembly.
Hope this helps.
Old Aug 27, 2009 | 03:37 PM
  #47
bigwilliefsu's Avatar
Default Distributor Question
Can anyone confirm that my 99ex (D16Y8) stock distributor is a "HitachI' brand? need to replace the coil and dont want to order the wrong one. Anyone who knows for sure please IM me willfsu5 on AIM
Old Nov 5, 2009 | 03:40 PM
  #48
Hondamister's Avatar
Originally Posted by imsquisht
Just bought this 94 hatch, have a accelaration problem,Step on the throttle hard and it falls on its face and sucks a lot of air.Slow accelaration it runs fine but you can not give it more than 1/4 throttle till you get theR's up.has a D15B Vtec 2601072 motor, 37820-P08-020 460 306860 Ecu,5 Speed anybody got any sugestions?
Steve
do u have a check engine light on cause it sounds like a tps or map sensor
Old Nov 5, 2009 | 03:48 PM
  #49
Default Has anybody done this swap before??????????
Ok i bought a 00 civic and the bottom end is done its a y8 but money is tight and i have a d16z6 motor laying around and i know i can use that bottom end as long as i use the oil pump from the y8 and head gasket but i dont know if i could use the y8 water pump because i was told there is slack on the belt but because the z6 water pump was used. I looked at the 92 water pump and the 00 water pump and the gears are diff so i dont know if it would be ok told dirve with it.
Old Dec 10, 2009 | 10:15 AM
  #50
quicklittlecivic's Avatar
Default 91 civic si trouble shooting.
i have a 91 civic si hatch with a motor and trans swap, my alternator is going out and i need an oil change, i was told its a zc motor but the only zc motor i saw on the list was a 1.6 l mine is a 2.2 how can i identify the motor so i can get my parts?
