Battery light
Old Nov 18, 2009 | 05:21 AM
  #21
Do not rewire. Get under the car and check/fix the harness. It's just one spot that always goes bad. There is no need to reinvent what is generally a fine product by the Honda engineers.
Old Nov 19, 2009 | 06:36 AM
  #22
Dipsetcivic117's Avatar
Hey mk378. Do the wires you are talking about also control the oil light. my situation is when driving at highway speeds 60+ and I break to get off the exit ramp, my oil light and battery light both come on. There has been 2 times where my car actually shut off. There has been some circumstances where if my car is on a declined slope. Rear higher then front. The oil light comes on the car sputters and seems like its going to stall out. Any ideas if its the same wires.
Old Nov 19, 2009 | 06:57 AM
  #23
have you checked your oil levels? because hitting the brake 2 60+ and the ramp would send the oil to one side of the motor and make the oil light come on, my bat light would come on when i was idling, i had the alt tested yesterday and it was bad
Old Nov 19, 2009 | 11:40 AM
  #24
Yea I checked the oil level. It was alittle past half. Car burns oil.
Old Nov 19, 2009 | 03:32 PM
  #25
lilytek's Avatar
sounds like you have a lose connection somewhere in the loop, i'de check alternator wires, battery wires, etc. Maybe you got a loose ground connection somewhere.
Old Nov 19, 2009 | 07:21 PM
  #26
When the engine slows down near the stalling point or actually stalls, it is normal for the oil and battery lights to come on. Engine not turning means the oil pump is not pumping and the alternator is not charging.
If your car drives OK but doesn't idle properly you should start by cleaning the IACV.
Old Nov 20, 2009 | 06:35 PM
  #27
the oil light comes on when at a stand still and tries to stall. the car turns over good. never had a starting problem. and the car does drive good, but does idle funny at times. ill check all the connections, and also clean the IACV. thanks
milhouse
Sep 26, 2013 05:31 PM
2468wdya9
Dec 14, 2012 10:48 AM
Knobmeister
Apr 14, 2012 05:47 AM
addiction2bass
Jul 24, 2006 08:57 PM
hockeyc574
Jun 22, 2005 12:22 PM
