Solved Problems (Check Here First)
Old Sep 20, 2009 | 04:19 AM
  #21
jddchatham's Avatar
Ok. It was off a tooth. I was lining it up where It was perfectly logical, but it did not want to time (proper marks on my engine model). So instead of relying totally on the lines I went and skipped it one tooth on purpose clockwise. Then started it and took timing, It was now way off. So then I skipped two teeth back the other way. This was my AHA moment! The timing dialed in perfectly. By the way before I started the engine I turned the crank by hand to be sure the valves cleared the pistons.
Old Jun 9, 2010 | 09:18 PM
  #22
civicalized's Avatar
Default speedometer trouble fixed
A tentative fix for erratic electonic speedos, worked for my 92 EXV
https://www.hondacivicforum.com/foru...t=82058&page=2
Old Aug 4, 2010 | 12:38 AM
  #23
Default ABS flush and bleed
Hi, here's a pretty interesting page, took me quite a while to find it.
http://www.danoland.com/nsxgarage/brakes/abs/abs.htm
As for the honda ABS bleeder tool, a 5/16" 8 point socket fits the ABS bleeder quite well, the pressurized fluid blows into the socket and I let it drain into a pan under the car, a rag wrapped around the extension attached to the socket caught a bit of spray, safety glasses on for this one!
On my 92 EX the ABS solenoid electrical connector is differant from the NSX connector on the linked page, but the concept is the same.
Old Aug 9, 2010 | 04:05 AM
  #24
99-00 D16y8 Intake Manifold not working with your 96-98 D16y8 Head? (or vise versa?) Here is why...
I found out the hard way, during my motor swap, that 96-98 IMs are NOT the same as 99-00. They appear to be in almost every aspect, but they ARE different.
The 99-00 Manifolds have an extra air injection system built into them, with these tiny little ports that WILL leak air and cause ridiculous idle surge if you try to attach it to anything other than an OBD2b head.
Here is a pic of the air injection holes.
I ended up bringing mine to a local welding shop and having them seal up the holes. Took em 15 minutes and I was back in business, idle surge free, shortly after.
Old Mar 12, 2011 | 06:55 PM
  #25
joered's Avatar
Default need help with a 01 civic ex that nun of my gauges are working
2001 civic ex runs great looks ok but i dont have any gauges and i cant tell how meny miles and the cruse not working
Old Apr 14, 2011 | 12:55 PM
  #26
Reymon's Avatar
Hi guys,
I want to know is the shocks and spring from a 2005 civic will fit my 2001 Lx 2 dr.
Old Apr 16, 2011 | 04:46 PM
  #27
BearTheGreat's Avatar
All them links are broken
Old Apr 25, 2011 | 10:49 AM
  #28
AZipper's Avatar
Strange non consistent grinding sound coming from passenger rear wheel well while driving over 50 mph.. bad wheel bearing? how can I check for that?
Old May 9, 2011 | 10:23 AM
  #29
SingleCamClutch's Avatar
i recently bought a 98 civic but this car is Frankenstein has 98 motor with 95 block and head...but my car wont turn on now..like it trys to crank but starts making a clicking noise..i went to advanced auto parts and guy said something is draining the battery yet i just bought a new battery? also guy said cant be alternator because he had me take off the positive piece of the battery to see if car cut off and it didnt..could it be i have a bad starter then?
Old May 9, 2011 | 10:49 AM
  #30
Questions don't belong in this thread. This is for SOLVED PROBLEMS, that is after you solve a problem come here and make one post about the problem you experienced and it's solution.
Start a thread in the main technical chat forum.
