Steering wheel?
Old May 25, 2009 | 05:39 PM
S2000 Wheel is GORGEOUS
Old May 25, 2009 | 05:41 PM
inthezoneac's Avatar
ebay usually has at least 1 listed
Old Nov 15, 2009 | 07:31 PM
packersfan117's Avatar
One problem with a new steering wheel from another car (i.e. the S2k) is that the ignitor for the airbag is often not included if you buy it from someplace like weksos industries or PWJDM. the reason behind that is that the gov't classifies the ignitor as an explosive device.
Old Nov 15, 2009 | 08:26 PM
supersize's Avatar
Sir Banned-a-lot
Gravedigger!
Old Nov 16, 2009 | 05:46 AM
justinwebb's Avatar
February 2010 ROTM
i have an aftermarket wheel in mine with a quick release. I just took out my whole airbag system. I love it and it adds an extra layer of security to the car
Old Nov 16, 2009 | 07:39 AM
hey, i have a quick question--i've been looking to get a JDM DC5 steering wheel or a s2k steering wheel for my 98 civic ex. are they direct bolt-ons or do i need to get an adapter or something to make it work?
Old Nov 16, 2009 | 07:36 PM
get AP1 s2000 steering wheel(any year before 04)
the steering wheel bolts up directly on the spline. The horn wires are a direct hookup as is the airbag.
For the cruise control you'll need to splice/re-connect just 3 wires since the connector in the column doesn't match the connection to the new CC switch. The wire colors won't match, but if you pair them in order how they're line up it works perfect.(top wire from CC switch matches top wire in steering column adapter, middle to middle, bottom to bottom. I just bought some butt connectors)
Just make sure you disconnect the battery before uninstalling/reinstalling the steering wheel. I forget what size, but you'll need a starbit to remove 1 screw on each side of the wheel that holds the airbag unit to the wheel. You can get it at autozone/advanced(they let me take a starbit out the the store to match the size). When disconnecting I turn on headlights and push on the horn, if nothing sounds or comes on I go right on and disconnect the wheel, although some wait like 10 minutes.
If you haven't already seen it, click below on My Civic to see what it looks like Besides lowering the car, I think it's the best thing I've done to it, looks so much better than the stock "granny" wheel.
Old Nov 16, 2009 | 09:27 PM
supersize's Avatar
Sir Banned-a-lot
can u take the cruise control buttons off? i would love to do that to my hatch
Old Nov 18, 2009 | 01:12 AM
EKSiR99's Avatar
im rooting for a spoon SW hahaha
Old Nov 18, 2009 | 02:11 AM
By the way, I have an 05 AP2 wheel on mine. Wired up, direct swap, everything included. 06+ wheels have a dual stage airbag and wont work on EKs.
