Are there such thing as legit inexpensive turbos?
Old Mar 16, 2010 | 11:59 PM
turbos don't use a header, they use a turbo manifold. Are you sure the stuff you are looking at is the right stuff or even fits together?
Old Mar 17, 2010 | 12:13 AM
crfnguyen's Avatar
ok i ment turbo manifold but the one he has is a b series so i gotta get a d series one.. uh i hope it fits... from what he said he ran it on his honda.... ill find everything out when i drive down there and take a look at it... but jsut to make sure if the turbo was origanally for a b series engine will it fit on a d series engine with a different manifold??
Old Mar 17, 2010 | 12:15 AM
you'll need a different manifold, yea. If you buy a manifold the same exact shape or close to it, it should fit no problem. If the manifold you buy is different, well you'll have to find out.
Old Mar 17, 2010 | 12:19 AM
crfnguyen's Avatar
alright cool.. like i said i dont know anything for sure untill tomorrow when i go get it..... how much do manifolds usually run for???
Old Mar 17, 2010 | 12:23 AM
Around $100 for no-name ones on eBay. As long as they're cast iron, no-name ones are typically fine.
But you'll want to try as hard as possible to get one exactly the same but for D-series, especially if it comes with the downpipe. This will make your install easier and help to reuse the downpipe it comes with (if it comes with one).
Old Mar 17, 2010 | 12:25 AM
crfnguyen's Avatar
dam i really just blanked out the downpipe.. i still need to find one of those too... hmm okay this is gonna cost more than 800. oh well i gotta just take my time on this project..
Old Mar 17, 2010 | 08:13 AM
Check on eBay for Honda CRX HF exhaust manifolds. You can usually find them pretty cheap... you can weld a turbo flange onto the collector and you have a cheap log-style manifold; not the prettiest thing on earth, but it's cheap and works. I'd imagine a muffler shop wouldn't charge much to fab up a down-pipe if you'd want to go that route.
Old Mar 19, 2010 | 10:25 PM
My04Civic's Avatar
Administrator
you get what you pay for, and for a turbo setup. i know i would put out the extra coin seeing as how you could be totally borked.
Old Mar 22, 2010 | 06:28 PM
KingCole7's Avatar
Well I found a kit but its for 2001-2005 Civic (Europe) or EP3 (I believe).
I was wondering if I could get it but just do some minor modification like pipes but as long as the manifold turbo and everything fits in the engine. Does anyone know if that would work...as long as I had some modification.
Old Mar 22, 2010 | 06:37 PM
KingCole7's Avatar
never mind I found out it was for a d16, but if someone thinks I can still do it, knowledge is great.
